LS1 BU said:What are the goals of the car. I woudn't run either of those cams. Much better options with better lobes than those two out of date cams. TR 224 isn't bad. I have some better choices. What is the Max rpm of engine. Where do you want' peak power to occur and what shift point do you want. Include trans type/ convertor/ gear and tire combo. Also what is the weight of car. Maybe I can help you out with selection. Bigger isn't always better. Some of the big LS1 cams drive like crap and will lose alot of torque down low. On the stock cube stuff in a heavy car I like to keep the IVC (intake valve closes) around 42-46 degrees that will give you a high DCR and keep low end torque good.
Its going to be a street cruiser with the 4l60e(shiftkit&2300stall), 373 cogs with 20x9.5" rears. The engine is a 98 ls1 with ls6 heads(ported&polished) stock intake and throttle body but 1.8 roller rockers which is why I dont want an overly aggressive cam just something bigger than stock but with good street manners.
