Lsx cst-v oil; pan
bowtie-1701
New Member
Mar 13, 2011
3
every body -talks about cst-v oilpan. has anyone actally used it? pictures please. i'm wanting to put a 5.3L in a my el camino
79loserbluebu
302
Illinois-60491
What engine mounts? I'll go snap a couple pics of the CTS-V pan using BRP mounts
On second thought, when the engine comes back out of the car I'll put some pictures up. You can't get the CTS pan in without pulling the trans back or the engine off the mounts.
blubaldmontess
872
Clarksville, TN
Mines almost done, I'm lowering mine 2.5" and needed to take the truck pan off to put on the CTS-V...will have pictures tonight:
http://www.ls1tech.com/forums/conversions-hybrids/817787-lsx-oil-pans.html
What do I think, well, the ctsv pan back (its deepest point) is 6.75" deep. The LH8 (Hummer pan I believe) is 7.5" deep, and the stocker truck pan is 8.5" Just to get an inch more is great, but how low is your car? If it is low or goign lower, find the CTSV pan
blubaldmontess
872
Clarksville, TN
Here are some pics, sits almost even, maybe 1/4" below the kmember:
Pics of the truck pan: on my car, same car same setup:
79loserbluebu
302
Illinois-60491
Appreciate the pictures blubaldmontess that's plenty of ground clearance
blubaldmontess
872
Clarksville, TN
I just realized how bad I need to clean all that back up again...wow, as for pics, no problem, easy enough to get occasionally
blubaldmontess
872
Clarksville, TN
as far as I can tell right now, 04-07 CTS-V cheapest new one I've found
http://www.gmpartsgiant.com/parts/gm-pan-oil-12605814.html
pmgm
144
OH
That pan fits good... What mounts did you use?
Thanks
