wessonracing said:I have mine running through the stock proportion valve. I put a 10LB residual pressure valve straight out of master cylinder that runs the rear brakes, and then to the stock prop valve. The brakes work fine although the pedal is quite firm.
Jimmy
another thing i dont think you need the factory porportioning valve when your using the set-up the way you have it !!!!!!!
