what trans cables will work connecting a 4spd auto shifter to a 700r4? will a shifter from a 200r4 work the same? what springs can be used to lower the rear of a wagon?
You will not be able to use the 4dr rear springs. The rear wagon rear springs will need to be retained or you will be in the weeds and they may fall out when you go over bumps.
