Ok guys, as most of the guys that have been on the board a fews years may recall, I have had nothing but problems with these.
Ok It all started when I did the first manual brake swap(before there was a aftermarket kit). I did the cnc cut plate and a factory malibu manual master cyl. removed prop valve, and installed a T-fitting for the fronts. Moved the rod to upper hoe.yadda,yada,yadda..
They sucked were horrible. So another new master, same deal brakes sucked. bought a S-10 manual master put it on same thing horrible braking. Changed pads, new complete ford drum brake kit on rear..still same. Bought new calipers,new rotors, new pads again, still the same.
Bought the TRZ kit figuring my woes were over......... :lol: Right I have had that kit on over a year, and my brakes still suck. No way would i consider let anyone else drive the car cause unless your a bear sized individual like me...it wont stop.
So all new brakes front to rear.. Hard lines and the flex lines as well. ive run at least 3 qts of brake fluid through it. vacuum,gravity, AND pressure bleed them as well.
It all started after the very first initial swap. So what do you guys think?? Oh i do the residual valve on the rear also.
The only thing that has stayed on the car since i did the first swap was the brass T-fitting.
