I did the exact same setup as yours, Qp rear drum brakes, factory discs on front, steel concepts brake cylinder etc. Brakes are kinda ok, allright driving around pits{track car} but stopping after a pass 11's @ 118.is kinda so so. I was thinking of the front discs or calipers. Maybe a larger caliper or an aftermarket front setup, strange etc. One quick question did you have the rear brake shoes arced to the drums? I just stuck mine in and had to look at an axle and saw that the shoes weren't making full contact. Take the rear shoes off and see if they're making full contact. I ran a 67 Camaro years back that had all drum brakes and it stopped better than my wagon. Keep us posted of the progress wagondude
GreenDragginBu said:toxicbu said:dont beleve the glaze is the problem , for me the pedal was way to hard to stop the car i had to push with both feet just to slow it down. glazed rotors will still stop the car the problem here is the car wont stop. this is why i whent back to power asist even tho i have to use a vac canister at least i know it will stop .
next season i plan to buy a after market mastor.
These are new rotors and pads in the front did the proper seating in on themalso. And just as Toxicbu described is to a t my same problem, although i use a aftermarket wilwood master that came in the steel concepts/trz kit. For me to stop it fairly quick i got to put my whole body into it, If i try1 footing it...It becomes a bit unsafe.
I know My wife could not stop the car if she drove it. And the other malibu I had with factory manual brakes, she could drive without problem.
But If there is anyone that has did the steel concept/trz master brake swap, within close proximity to Cleveland.Ohio.. I would love the chance to see how their car brakes, and they can drive mine....just so I know I'm not crazy.
