nitrous pressure guage...
cool, I figured it should stay pressurized for a while. Thanks for the reply. I have some leak tech in work I can use.
:thanks:
Hiway
3,932
Enola Arkansas
Pressure gauges are need for both....as close to 950 on the bottle which is around 85 degrees or so. Bottle heaters are usually needed. Around 5.5 on the fuel...flowing thru a 75 jet or your plate. Once a bottle gets to around 17 pounds, there isn't a full pass left in it for me anyway. Don't forget about timing. Like sex...Read read read before you spray if it's your first time.
