What do you mean by metric?
I have lots of buddies putting S-10 straight ratio power steering boxes on A-bodies.
The quick ratio boxes found on Monte SS and Grand National look just like the A-body box, the was another box with a freeze plug looking top.
If you are referring to the o-ring seal flare fitting it hit GM cars in '78-79 trucks later. To use an early pump swap the pressure regulator fitting or vice versa.
If you american, like the saginaw box, they still make and use them. I put a quick ratio box (I think the casting number was like 656 or 686) it is found IROC Zs, GNs, and some cop car Caprices. I have a 454, long water pump, and some reproduction GM power steering pump brackets that seemed to be for a 427 '69 Camaro, or at least that was the pump I ended up buying at the parts store. I just swapped out the pressure regulator and used '86 Monte lines.
