LS6 Tommy said:Sorry guys, I am a total screw up!The responses I've gotten from you all prompted me to think that I'm getting rusty and I'm remembering things wrong. I got out the old GM manual, and sure enough, I was. The combo valve doesn't isolate the two circuits, as I thought it did. I have edited my FAQ's sticky appropriately.
Apologies to all I may have confused or made angry.
You are actually not entirely wrong. The stock proportioning valve on most cars from the mid 70's up until the advent of abs have a slider valve inside of them that will, when working correctly, shut off fluid AFTER the other half runs out of fluid. You will usually hear a small pop and the brake light will come on. Normally this will actually improve the pedal feel and you might not notice the car stoping much different if it's the rear brakes with the leak(which it usually is). If it's the front with the leak then you will have a hard time getting it to stop.
Having said that, Pretty much all masters have the fluid divided between front and rear halves. Even the single tank masters that don't look like it has a divider has a small dam inside. If you have a leak in one half or the other you will need to pump the pedal up to get a decent pedal but it should still stop the car very near the bottom of the pedals travel.
I know that I'm a new guy around here so nobody knows me or if I know what I'm talking about. I Understand that..... Just so you know I have been doing brakes and alignments as my occupation for nearly 15 years for a shop that has been in buisness since 1952. I know the stock stuff and the theory pretty well but I'm not familiar with all the different kits that the various aftermarket supliers sell. I have done a number of drum/disc conversions on 60's muscle cars though. I only post info that I have experience with.
