Put in some trick springs today
78pontiacibu
170
Morristown, TN
www.facebook.com
I just installed a new set of trick springs in the rear of my car today and my car is higher on the driver side by close to an inch. Did i do something wrong? Do they just have to "settle"? I know there is a left and right, i put themin according to the little metal rings on them.
UMI Sales
254
Hey 78.
Did you buy them as a matched set? New or used?
Did the car sit correctly prior to the springs?
Can you swap them side-to-side and see if the problem switches to the opposite side?
ramey
78pontiacibu
170
Morristown, TN
www.facebook.com
grizwald said:
when you're in the car, it should level out.
After i posted that, i realized my weight would even it out. LOL!! I got flustered because i had a whale of a time with the front springs and getting it to sit right in the front. I later found a ball joint not seated all the way.
