Rally Gauges to dark
SLICK78
1,120
La Porte, Tx
malihoochie said:
Wow! That made a huge difference. I still like the led bulbs though.
look in the beggining of the thread I replaced all of them with leds from superbrightleds.com
malihoochie
875
michigan(detroit area)
Slick78 - I know. I read it, but even though the greatest gain seems to have came from trimming the speedo - I still like the idea of the LED's. Job well done =D>
SLICK78
1,120
La Porte, Tx
yep I think so to. but the piece of mind that comes from knowing I will not have to pull it apart again to replace bulbs is worth it
79izfine
2,199
massachusetts
thanks for the info slick78 ,,, will put on the upgrade list ,,,,was that a factory gauge set up ,,,, if not was it difficult to change wiring ,,, i have the same gauge set up from a monte with the clock etc but will have to manipulate wiring ,,, thanks
SLICK78
1,120
La Porte, Tx
no problem and yes my car had the rally gauges from the factory...But this should help you check it out
http://www.maliburacing.com/gauge_conversion.html
SLICK78
1,120
La Porte, Tx
no problem...
SLICK78
1,120
La Porte, Tx
pretty sure I ordered the cool white
