Help me hook decent power. Don't have a dynosheet but it should make 650-750hp maybe more not sure. 3600lbs cutlass.The suspension is basically stock with 90/10 and 50/50 drag shocks no front swaybar poly bushings and a spohn arb, and about a coil cut off the front springs and belltech 1 1/2" lowering springs in the back.
355 sbc 8.33 comp
procharger f1a 18-20psi
afr 195
comp solid roller .585 lift 255 265 @.050
quickfuel 750 blowthrough weiand team g intake
1 7/8 shoenfield headers with 3 1/2" pipes
th400 with a brake and a 10" converter stalls about 3800
moser 12 bolt with 3.73's and a 28x11.50 et streets
I dont have a time slip with this combo but my time with my old setup was a 11.85 @ 113 with a 1.71 60' with a weiand 142 @5psi, nx268h cam and a 2400 stall on 275/6015 bfg drag radials
Anyways it does not hook at all, where should i start what works. lift bars? double adjustable shocks? different springs? instant center, pinion angle etc?
thanks for your help
355 sbc 8.33 comp
afr 195
