SB to a BB in a 79 bu w/ factory air???
bww92ls1
76
Smiths Grove, KY
Looking at a big block install in my 79 bu. I want to keep everything as factory as possible. I would like to have ac working later on, and I am planning on full length headers with no slip joints.
Is this a simple install and if not what will I be up against?
Can I use the stock stye small block motor mount?
Are there any other clearance issues?
Is there a stainless header offered for this application?
What's a 427 2 bolt main low horsepower passenger big block worth that needs going through?
If you stick with factory style valve covers & use a long style H2O pump, you can use an A6 compressor, 70-72 BBC compressor brackets & mounts that are readliy available from Chevelle resto companies. My '80 229 V6 used an A6 compressor from the factory, so I'm just going to reuse it. I also used a bracket & pulley kit from Burt Chevrolet that has crank & H2O pump pulleys, power steering & alternator mounts & hardware. They say most of the parts are from 90's late model truck. I don't have the invoice here at work, so I can't give you a part#.
Burt Chevrolet 800-525-5096
79izfine
2,199
massachusetts
if your bbc isnt complete i have a factory intake from a 75 454 that i dont need thanks
injected
432
Quebec , Canada
can you tell me if after market valve cover will clear the a/c box ??
The Edelbrock's in the pictures in the link in the next post form 79izfine are the only ones I can say for sure will work.
