Sparkplug going crooked???'s
dickeymoore
818
Atlanta,Ga.
Will change back to the other Champion plugs,I hope the tap will fix my problem or I will have to remove head for a machine shop job. :cry: :cry: :cry:
SSedan64
948
MACON, GA.
If the Cleanup Tap doesn't work, there're Inserts you can install without removing the Head.
Example >>
Other brands also available.
psychomotors
896
Bonne Terre, Mo
Just read this. Glad you got it fixed. Just an FYI-Autozone sells a kit that taps out the hole to a larger size and then you screw in a new insert and tap it with a hammer and special included punch and it works like new. I have used it on an 8 hp Briggs & Stratton go-cart and my Brodix Track 1s.
