Ok It's been over 3 yrs since I messed with my suspension, I know Im lazy. I have SSM lower control arms, adj. uppers, and an anti-roll bar. I know some will say that the Lift-Bars and the ARB will act against each other with hi HP cars (600+HP)... well I agree. The best 60ft I got is a 1.39 and Im consistence in the low 1.41-1.45 range. I still consider this isn't bad 60ft times with a full interior Monte (3500lbs)... one reason I haven't touch it. lol No matter what I do (add more nitrous, lower tire psi, change shock settings, add more pre-load) my 60ft will stay the same or won't improve. I know the car is making power with more MPH showing on the timeslips, but no change in the 60ft resulting no ET change. The car should be running 9.60's with the MPH I have (140). So over the winter I plan to work on my suspension with no money or little cost.
Ok the questions...
Can I remove the brackets the SSM gave me and run without them? Wouldn't this be the same if I ran non-adjustable boxed control arms?
If I run the SSM LCA in the factory bolt location (rear-end), does it still need the plates (brackets)? There will be some play (a gap) if I leave out the brackets when bolting the control arms to the rear-end housing.
I like to hear back from guys that removed the brackets and can tell me if it made a difference? I also like to hear from anyone running 1.3x 60fts. lol
Thanks for the help
-Mark
Ok the questions...
Thanks for the help
-Mark
