turbo 400 or 2004r to lq4
LSJM1
134
Atlanta
First I want to run a 2004r to get going and swap to a 400 later.So I can bolt up either to an lq4 with it's stock flexplate and spacer and not have to have a special convertor with an ls pilot?
knievel
270
Hillsdale , MI
I have currently been checking in to this
A 6.0 lq4 from 99-00 the crank already has the flange built in along with a flat flexplate. the t400/200r4 will bolt up and converter will work
I believe any lq4 that originally came equipped with a 4l80e transmission will already have the correct spacer and flexplate.
If you end up with and engine that needs the spacer I believe you will need to order the flat flexplate for the converters to line up
455_82malibu
1,400
WISCONSIN
if its a HD truck with 4l80, your set, if not you just need the spacer. Holes in the flywheel just need a little time wih a dremel.
Or a converter made for the stock flywheel, btw i have a yank 3600 for the 200r4/ls1 for sale.
