Comparing Lynch to anyone is kind of a joke. He has no budget, he races/tunes that car full time, and he's got more resources/crew than most professional teams do. Other turbo cars can't touch him, nevermind Procharger guys.
boostedmalibu said:Some one was stating that prochargers dont create heat anytime you compress air your creating heat. and yes you must run an intercooler on a turbo unless your running alky
CutlassRacer said:Anything boosted that is making huge power with gasoline for fuel needs an intercooler to make maximum power. A blow through carb will knock a little of the heat out of the air charge, but not enough when you really start leaning on them.
malibu795 said:a GT4088R can generate air temp upwards of 350-400* IAT before CAC/IC running full boost of 55-60psi
withthe excemption of alky... everything need a cac/ic or water/methanal mixture if not running a CAC.
if not your ehuast gas temps will go through the roof. talking 1800-2000*F or more.
