Weight loss checklist
10secBu
4,284
Westminster, MD
5-door said:
You might find this hard to believe, but a Ford 9" is lighter than a 12-bolt. It's even lighter than a 10-bolt.
I'm not sure if I would buy that or not. If that were true, then why would some NHRA Super Stockers and Comp eliminator cars run a 12 bolt (I've seen dragsters with GM 12 bolts...I've even seen Mopar S/S cars with GM 12 bolts. I guess it could also be less parasitic loss due to the pinion to ring gear position. But a stock 9" with an iron center section, I'm pretty darn sure the 9" is heavier than a 12 bolt.
Not having weighed either side-by-side myself, I surely could be mistaken though.
Supe
15,116
Charlotte, NC
You know, my rear end guy also swore that a 9" was lighter than a 12 bolt. I guess this could also depend on whose housing it is (stock or aftermarket), and what chunk/axles you're using.
moneys is no object?
9" moly housing, titanium 1 piece tube axle, titanium flanges and studs, raised pinion center section, titanium spool, and yoke
Robert1320
Something like this...
Of course with carbon fiber brakes
no thats still heavy, you need the pro stock not in the catalog stuff. :D
:lol:
actually the best bang for the buck is a 9" moly housing with a 12 bolt aluminum center and 33 spline axles.
Turbo1dr
2,232
New Bern NC
www.turbomalibu.com
sleek79 said:
and after all this how light is the car going to be??
Light enough a stock 305 can get you in the 13's!
Robert1320 said:
Just more hp. Bigger N2O jets, Smaller pulley, Bigger Turbo!
That's how your suppose to think! It's not the weight you loose from the car that boosts a mans ego it's the amount of HP his car makes! Oooooh Yeah! :twisted:
