Unpacekd, inspected and inventoried my Torque Tech exhaust system. These pipes are nice! It's really too bad they're retiring and no one is taking over the business.
melloelky
3,654
31
mass
that is too bad,hate to see that happen,i think you should take over the reigns Tommy :mrgreen:
Greaat, buy a business with zero money, relocate 12 hours away to a state where the heat will kill my wife in a week... :lol:
malibuguy
3,775
Finksburg, Md
Took a chance and bought a cheap high flow fuel pump and some new plug wires for the turbo car.
The stocker...just been driving it.
malibu795
1,497
4
spgfd ohio
Caught a screw in both rear tires one wenth through the sidewall.. Forced me to buy two new tires.. Only place that had 275/40/17 was Jegs and all they had was MT new super comp tires.. At 160.00 each.. Maxxis doesn't make the MA-V1 anymore.. Which I really liked..
Got the 68610 headers on, new R42 plugs full 3" dual exhaust to the axle for now.. Running down flowmast felt 44.. Hopefully once tail pipes are one the drone will die down inside.. Changed both front calipers since they where frozen and oil change
1981Regal
1,274
Cincinnati, Ohio
New rear springs moog 5379 - new center link and idler arm - one side installed new coil spring moog 5662 and upper ball joint replacing the original one. Next is to finish the other side front coil spring and upper ball joint.
Rear seems okay but looking low for stock height. Front came up about 3 inches. Definitely trimming them after they are both installed and settled in. Looks like it's launching sitting still.
Tailpipes help drone a lot, but Flows are noisy no matter what.
malibu795
1,497
4
spgfd ohio
Been running these for while yet to burn them out.. 3" 3 disc
I'm sure long roof wagon has part in it as well... Plus if I has room to rotate the mufflers so they are vertical vs horizontal would help alot as well
Edit just saw you can build your own versions
What 3" 3 disc sounded like with 2.5 exhaust
