malibu795
1,497
4
spgfd ohio
First time she has been on a dyno in ~6 years and some 60,000miles. did 305/432 with 200 miles on it and smaller tires
Kinda stoked :)
1981Regal
1,274
Cincinnati, Ohio
Got my jeep shaft and "z" quick ratio steering box installed temporarily. Need to take them off and get some paint on them so they look a little more presentable.
1981Regal
1,274
Cincinnati, Ohio
Malibu795, What jets are you running in the 600 cfm? I think I may try it out. Let a buddy barrow mine should be getting it back soon.
malibu795
1,497
4
spgfd ohio
Pretty sure secondary is a .110
Primary are .098 with a 73x47 rod and 10inhg step up spring.
Lift pump is a basic summit ~6psi 80gph mechanical pump with -6 line from the fuel tank
malibuguy
3,775
Finksburg, Md
Ordered megasquirt for the turbo car. Tired of trying to get the carb right at this boost setting.
malibu795
1,497
4
spgfd ohio
1981Regal said:
Thank you
I didn't get a chance to check the primary jet.. I'm 90% positive I set it up with 750cfm seting.. Rather run out of air vs run out of fuel. And with quick rod change I can richen up if needed
malibu795
1,497
4
spgfd ohio
1981Regal said:
Oh okay so it's setup like a edelbrock 1407?
Pulled top
Rods are
73*47 for cold/winter weather
75*47 for warm/summer weather
Primary is 398
Secondary is 398
When I dyno'd I pulled low mid 13-13.6 AFR. With you increased CR ID run a 400-410 secondaries
I'm calibrated close to the 1406 and I can get some black smoke out the exhaust
With the cam/CR you have ID shoot for close 1406 calibration
Primary .098,
Secondary .095;
Metering Rods - .075 x .047; pick up following rods
73*47 #1456 (24) ref to 1406 chart)
73*42 #1455 (23)
73*37# 1454 (25)
A 73 rod is ~4% richer then a 75 rod same thing with 47 to 42 at each step. A 37 rod is 8% more then 47
If your worried pick up
70*47 #1452
70*42 #1450
70*37 #1449 (19, is ref on the 1406 chart)
I'd pick up a another pair of 098 jets(#1427) for secondaries 095 to 098 is 4% richer
The calibration are pretty drastic.. But remember you cutting 20% or 150cfm from the carb. The end result, 4% rich/lean is a big jump on a 600 vs 750
1407 is
Primary .113,
Secondary .107;
Metering Rods - .071 x .047;
Step-Up Spring - orange (5" Hg)
As for sizing with Edelbrock subtract 300 from the number 398 is a "98" 400 is "100"
Rods 75*47 is the biggest rod they make. The first number is your high vacuum fueling (cruise), 2nd number is your low vacuum fueling(power).
The stepup spring comes in 5-6 inHG ratings. That tells the rod when to swich between cruise/power part of the rod.
Higher the vaccum rating sooner the change happens.
As for example I cruise at 18-20inHG I run a 8" HG spring. It will bring more fuel in quicker then a 5" HG spring since I have to put more load/open carb more to reduce vacuum enough to lift the rods.
The goal is a "smooth" transition..
The only main thing different betweem the 500/600/750cfm performer series carbs are primary bore size. 500/600 are the same and are smaller then the 750cfm carbs.
Secondaries are all same size, and the 750cfm primaries are same diameter as the secondaries
As for ignition, it's not stock and fairly healthy.
I have, MSD 6A, with billet dis, and a blaster SS coil, 8.5mm super conductor wires AC delco R42TS plugs set at .060" gap.
So that winded explanation done... Id pickup the 3 .073 rods I mentioned and a second .098 jet for secondaries. Rods are ~$13.00 jets are ~$7.00 each
