What rim width?
DOUG213XRJ
4,671
West, MI
Hey, I have 215/65/15`s on the front my cars with a 7 inch rim. On the rear I run 295/50/15`s with a 8 inch rim, 245/60/15 on a 8 inch rim and 245/60/15 on a 7 inch rim. So I would go with a 7 on the front and a 8 on the back. Doug
lurchsmalibu
3,774
Lakeland, Florida
6" to 8.5" for the 235.....
7" to 9.5" for the 275....
tirerack.com, type in what size tire and click on SPECS and it will give you a range recommended by manufacturer.
Alexander
318
Iceland/Norway
Thanks, that will come in handy ;)
1979dbkohl
99
dubuque iowa
What about backspacing? The rim I want only comes in 4.5. Backspacing I plan on running the same tire combo. Will I have enough clearance? 15x8 rim front and rear
lurchsmalibu
3,774
Lakeland, Florida
For the front you should be safe, for the rear you might need a 1/4" or so spacer to keep from rubbing on the frame rail IF your frame and wheelwells are factory. It might also benefit you on the rear to roll the lip on the inner wheel opening so it doesn't slice up a tire in any uneven surfaces while driving.
