Wheel fitment with 12 Bolt???
JBreu
321
Livonia. New York
I have a problem and I think I solved it .....Just wanna be sure is all.... I have a '84 Monte with the 12 bolt rear from a '69 Chevelle.....Running Weld 15x10" wheels with a 6" back space ( I think).. I keep eating the outside of the tires and rubbing the inner wheel wells when I have a few people on board..... After doing some math and checking the FAQ I think I need 15x8 tires with no more then 4 1/2" back space..........Oh yeah, I have the 275x60x15 tires. Is this a correct theory I have????
"This isn't necessarily something set in stone, because you can tweak things to run a pretty big tire. Some people are interested in drag racing, some want the biggest wheel diameter with ultra low profile tires. Since this is primarily a drag racing site, I'll say that a 275/60/15 is the largest rear street tire you can run and a 28x10.50 is the largest slick. I found that the McCreary L60-15 fit nicely. These should be used with 15x8" wheel and 3.5" backspacing. "
So with that in mind.....I believe I need the 15x8 wheel with the 4.5 back space to compensate for the width difference in the 12 bolt compared to the 10 bolt?? Thaks in advance!!!
kevind
868
Whitley City KY
When I ran a 68-72 Chevelle 12 bolt in My Malibu with 8" wheels I ran 5.5" back spacing. They still would rub the 1/4 panel lip sometimes with a 255/60R15 or a 28x9 slick. I don't think a 4.5" backspace will work it will be in rubing Your 1/4 panel.
bowtie81
5,008
sarnia, ontario canada
I have a 12 bolt from a 67 chevelle and i run 15x8 with 275-60 with 5.5 b/s, i think the 68-72 12 bolts are wider and i believe you need 6.5 b/s....
JBreu
321
Livonia. New York
TTT-Anyone else?? I think maybe the 15x8 wheel with 4.5 backspacing might work???
TOMS78BU
4,896
gadsden, alabama
Go with 5.5 inch backspace.
Ed Cannon
1,682
Johnson City Tn
My bu has a 68 Chevelle 12 bolt. I have 15x8 with 5.5 back space I have Hoosier QTP's 10x28x15 no rub but I have a mild frame notch. I have had 275 60's on it with a bunch of room.
godjay
105
Rantoul, IL
my bu has 12 bolt but dont have brake drums yet...is there a way I can tell what year i have I looked all around the rear end for numbers but cant find any or maybe im not lookin in the right place for them also I did some research on here and thought I might have to notch and lip work before I did my research for my 15x8 b.s. 4 1/2 so I noticed that the 12 bolt is wider than the 7.5 and 8.5 and if Im correct 10 bolt as well so my main question is maybe all I will have to do is work on the lip to make the 4 1/2 b.s. to work thx Glenn
JBreu
321
Livonia. New York
Actually I'm switching to the 15x8 with the 4.5 backspacing...I'm gonna try those next weel as a buddy of mine has a set he'll give me.........I'll let you know. measure your housing width and compare to this :
64-67 Chevelle 54.250"
68-72 Chevelle 55.250"
These are flange to flange I believe
