Wheel tubs
Strokin
11
Doing my first backhalf. I get conflicting info on how to attach wheel tub to quarter panel. Welded or sealer? On a Monte Carlo ss. Also any ideas on trunk hinge? Just move them in?
melloelky
3,590
mass
go with the seam sealer it won't absorb moisture like the silicone will.
10secBu
4,284
Westminster, MD
DO NOT WELD! You will warp the quarter panels, even if you do body work it will show some time down the road.
Fit the tubs to have a 1/8" to 1/4" gap from the edge of the tube to the inside of the quarter panel. Do not fit the tub tight against the quarter panel.
We use urethane seam sealer. Put tape on one side and apply a bead to the opposite side, allow to dry, then remove the tape and apply a bead to the opposite side. Trapping the edge of the tub between two beads is the strongest method.
Strokin
11
So welding tubs to the inner skin or old tub isn't an option? Or is there not enough left?
10secBu
4,284
Westminster, MD
Strokin said:
Thank you, really helpfull. Any thoughts on hinges?
If you just do the inner wheel well all you need to do is remove the factory hinge brace and make a new one to attach to the squared off fabricated inner tub.
If you do a full tub then you may need to modify the hinge depending on how high you mount the tub.
10secBu
4,284
Westminster, MD
Your either gonna need to fabricate a custom hinge, or like myself I removed the hinges completely and went to a fiberglass deck lid that is attached with dzus fasteners.
Strokin
11
So started my backhalf with frame off. I purchased a separate frame for project. Looking at my existing car with body on frame, it appears the 33" tires will rub on quarter, unless I move axle centerline back. How's people experience with this? Minor body work? Move centerline to your desired spot and change wheelbase? Help plz
Strokin
11
To clarify, it looks like it would rub on the front lower portion of wheel well, but has lots of room in the back
Strokin
11
Ok I can appreciate that.but do I center axle to the wheel opening or stuck with stock clearances?
10secBu
4,284
Westminster, MD
If the back half is already done your limited to how far you can move the axle as is. I limit threading 4 link bar rod ends out to 5 turns most of the time. If you wanna move it back a noticable amount then new longer 4 link bars may be needed.
You can center the rear in the opening how you see fit really, just look at it closely as you do to make sure it looks in proportion and doesn't look odd how it sits.
Strokin
11
Thank you guys it's all helpful
I haven't welded in or cut for backhalf yet, as I was stuck on this part.
Even if I center rearend in wheel well I have 1" either side at best so sounds like stretching open wheel well
S wheel tubs and sheetmetal Suspension Technical 0
gstock8732 anyone with experience with wheel tubs in central jersey? Autobody/Paint Technical 6
gstock8732 Wheel tubs!? Autobody/Paint Technical 15
D Wheel tubs up front... Autobody/Paint Technical 19
A Tire/Wheel Combo w/stock tubs & frame rail Wheels/Tires/Brakes Technical 16
primerbu wheel studs Wheels/Tires/Brakes Technical 0
primerbu Wheel studs. Drivetrain Technical 0
7 Wood steering wheel Interior Tech 3
V Brake swap, wheel alignment? Wheels/Tires/Brakes Technical 6
widomkr79 Play in my steering wheel Suspension Technical 3
unclepudge Wheel Studs Drivetrain Technical 4
P Wheel lug questions Wheels/Tires/Brakes Technical 1
78_Landau Need help... BAD wheel hop!! Drivetrain Technical 8
B adding 1/2 in wheel studs Wheels/Tires/Brakes Technical 1
W Wheel Fitment Wheels/Tires/Brakes Technical 3
richamer1 Steering Wheel 90 degrees off Suspension Technical 3
D Wheel questions Wheels/Tires/Brakes Technical 6
E Tilt Wheel question Interior Tech 3
D Steering Wheel Disconnect Interior Tech 0
D Horn button help - Monte Carlo steering wheel Interior Tech 5
AllMtR85SS Monte ss frame notch tire/wheel question... Wheels/Tires/Brakes Technical 1
P steering wheel quick connect with factory column Suspension Technical 7
t5montecarlo Sudden Continuous Screetching Sound at Left Front Wheel Wheels/Tires/Brakes Technical 5
cantwaittill420 Stop my wheel hop. Suspension Technical 6
D 4 wheel disc brake setup help! Wheels/Tires/Brakes Technical 5
G 255/70 on 15x10 wheel? Wheels/Tires/Brakes Technical 1
D Wheel Studs! Wheels/Tires/Brakes Technical 2
TTLSX418 Wheel Question... Wheels/Tires/Brakes Technical 1
bigbadbu Wheel cylinder clips Wheels/Tires/Brakes Technical 0
M 17x7 vs 17x8 front wheel Wheels/Tires/Brakes Technical 2
Alex41 Wheel hop....isn't getting better either. :( Suspension Technical 26
S Wheel size for my malibu Wheels/Tires/Brakes Technical 3
nillabu Looking to center rear wheel in opening Suspension Technical 3
Z 7/8 wheel cylinders Wheels/Tires/Brakes Technical 1
7 Wheel problem Wheels/Tires/Brakes Technical 1
J wheel,s will they fit Wheels/Tires/Brakes Technical 5
chevymc350 11" or 12" wheel??????????? Wheels/Tires/Brakes Technical 1
P wheel studs Wheels/Tires/Brakes Technical 6
7 Quick question about front wheel backspacing Wheels/Tires/Brakes Technical 2
BOWTIEKID Wheel Fitment Question Wheels/Tires/Brakes Technical 0
81rustabu weld wheel ? Wheels/Tires/Brakes Technical 4
8 LS1 brakes with 15 inch wheel Wheels/Tires/Brakes Technical 6
bigbadbu 12 bolt wheel questions Wheels/Tires/Brakes Technical 1
D Aftermarket a-arm wheel clearance Suspension Technical 2
B wheel help Wheels/Tires/Brakes Technical 3
C Question about wheel and tire combo with drop spindles Wheels/Tires/Brakes Technical 2
S Tire Wheel Combo ? ? ? ? Wheels/Tires/Brakes Technical 2
D Wheel adapter thickness + info, 17x9(?) F/Y-Body wheels Wheels/Tires/Brakes Technical 3
S Controlling wheel hop? Drivetrain Technical 21
S Wheel Fitment Guide Wheels/Tires/Brakes Technical 0
Similar threads
