new ground up rewire bracket car
Discuss all electrical and wiring issues here.
Moderator: Moderators
Post Reply
rich
Contact:
Post by rich » Sun Mar 06, 2016 6:35 pm
bracket race only bbc no spray carb throttle stop transbrake setup looking for a good plan to rewire car. nothing is bought yet looking for ideas and a good plan I may buy a electronic dash logger type setup. idk ideas dos don'ts .
I'm an electrician by trade just looking for products and ideas thanks
Ed Cannon
Re: new ground up rewire bracket car
Post by Ed Cannon » Sun Mar 06, 2016 7:12 pm
I work on auto electrical for a living. I don't wire race cars but I have wired my Malibu. I crimp solder and heat shrink every splice and connector. Some say solder joints can break on a race car, I call B.S. on that. Ive seen and repaired many broken solder joints on circuit boards but never a crimped connection in 25 yrs. That being said, I would buy a 10 or more ckt fuse block, I would use ground buss bars under the hood and inside. I would use Bosch style relays to power up all my motors and pumps. I would most definitively use quality parts from. > http://www.colehersee.com/" onclick="window.open(this.href);return false;
80 Malibu. 496 pump gas.
10.09@132 N/A
6.33@109 n/a 1.38 60ft. With South Side bars!
9.75@135 100 shot.
A stupid question is better than a stupid mistake!
rich
Contact:
Post by rich » Sun Mar 06, 2016 7:29 pm
i'll have to look at that site thanks
10secBu
Post by 10secBu » Sun Mar 06, 2016 10:59 pm
I used a switch & relay panel by K&R, makes for a neat install and includes all labeled wires & connectors.
Ed Cannon
Post by Ed Cannon » Mon Mar 07, 2016 8:13 pm
^ That's top notch work there. Did you wire that? Its nice to see solid wiring for a change. I see so many blue and yellow but connectors on really nice race cars, and hack wiring jobs, it amazes me they run at all. Its time consuming to wire things up properly but it is worth every second and penny to do it right. Your car is a fine example of that.
10.09@132 N/A
9.75@135 100 shot.
10secBu
Post by 10secBu » Mon Mar 07, 2016 8:56 pm
Thanks, yes I did all the wiring. I have a background in low voltage wiring. Did high end car audio for 5 or 6 years, then residential/commercial security/cctv for another 5 or 6 years.
gman415
Post by gman415 » Tue Mar 08, 2016 8:17 am
Nice work!!
K&R has some nice stuff
Tim
< Worlds slowest 7.00 car!!!!!!!
rich
Contact:
Post by rich » Thu Mar 17, 2016 1:06 pm
todd thanks for the pics great job on your work you always do great work
Post Reply
