16V conversion
8secChevy
229
Williamstown, NJ
X2
jays81malibu
51
London, Ontario, Canada
I can't really see the advantage but...
-16V battery, don't ask me where to get one
-thicker wires, since you'd be running that much more amperage OR higher resistance bulbs and motors so you don't blow them OR bulbs and motors rated to run at 16V +
-Alternator that will charge at approximately 18V or better
And theres other things, this is assuming you're not running a computer controlled engine/transmission and if you were it would just be impossible lol.
grizwald
3,300
Ontario, Canada
this is what i was wondering. everything in the car is made to opperate on a 12V system. so it can't be just change the battery and go. last fall the alt cooked in my car and i ran all weekend without it. i charged it between rounds, no big deal at all. so now, i'm thinking about not running an alt and was wondering if going 16V would be better....just brainstorming i guess.
Higher voltage = LOWER amperage.
X2, but only if you have the proper bulbs. If you aren't running any other electronics it would be beneficial to check on your coil/module as well, I'm not sure how they react to the higher voltage... coil should be fine but the module may be sensitive.
jays81malibu
51
That's only if you plan on changing all the resistances in the circuit.
Voltage / Resistance = Amperage
12V / 4 ohm resistance as an example = 3 amps current draw
16V / 4 ohm resistance = 4 amp current draw
So you'd probably want to change that to a 5 ohm resistor. You can see how that might get time consuming lol
Excelerater
6,798
Memphis,TN
I run 16V......In a race car Ill never run 12V again.....
Nothing needs to be done to make the change over as far as I know,I didn't change anything ...
Everything runs better though,IGN,PUMPS,NOIDS,STARTER ETC....
