Yup, did that. Those are good. Problem is ive got about 83 connections underneath(temporary) where it could be. My gut is still telling me at the collectors though.StreetBu said:Double check the exhaust manifold gaskets to the head. I bet that's where it is.
388bu said:Heres the quick overview of how I did the swap:
Mounts
Carshop inc standard mounts and re-drilled the frame after positioning the motor exactly where I wanted it. It is set back about 3/4 - 1".
Oil pan
CTS-V pan FTMFW!!! Unless your car is REALLY low, then this is the pan to use! My headers will scrape before the pan does. It hangs about 3/4" below the front crossmember.
Thanks.Ribbedroof said:388bu said:Heres the quick overview of how I did the swap:
Mounts
Oil pan
So, my question is, where is the back of the block in relation to the OE location? Do I understand correctly that the block/bell junction is approx 1" closer to the firewall than the original setup?
And, part 2...Does the CTS pan require that much setback to clear the suspension crossmember?
And, part 3....Any idea on A/C compressor clearance?
Trying to map out the best setup, but I will need to keep an un-notched crossmember, and really need to keep the A/C on the car. I'll be using an 02 LS1 sourced from a Camaro. I see Kwik makes an A/C relocation kit for about $200, which then requires a Sanden compressor, so I'd prefer to avoid that avenue. Also concerned that setback will cause coil-A/C box problems.
Good work, though. I'm impressed with how quickly it all cam together. Doesn't seem like that long ago I saw where you were talking about leaning to an LS swap, and here we are all done. =D>
No, I am running a MAF. Some people lose the MAF and run in speed density mode however. I think people mostly start doing this in high horsepower boosted applications generally.bowtie29 said:You are running a MAFless system right. Whats the advantages/ disadvantages of this because I would think that It really wouldn't make that much difference. I would almost think the computer would need the MAF sensor to run the motor.
Yup, sent both to him. It was a little less than 2 weeks turn around.78Bu88SS said:388bu said:It was very cheap. $360 and that includes the ECM tune. If you find something cheaper, id be VERY surprised.bowtie29 said:That sounds like it would make things very nice, neat, and easy. Did he have to break you piggy bank? Sounds like if the cost is low, it would be much better/easier than running a completely different EFI system.
Jesse aint no dummy either. He used to work for GM in this line of work. Writing the code for the ECM's I believe.
Did you have to send him the harness and PCM or? Im debating going to fuel injection at somepoint and weighing my options right now.
