4-speed worth looking at?
4,761
I have chipped teeth on a few 3.50 Saginaws. The 3.11 version has a more even gear spread than the 3.50 version.
Did you ever see the pictures of my exploded 3.11 Saginaw? It was behind my 305. It did not like a first gear clutch drop while already in motion, which I had done many times before. First gear peeled off the cluster.
You probably have been lucky because you don't have limited slip and are spinning a tire rather than gripping the road. My wagon had limited slip and 2.73 gears.
Multiply 1st gear x your diff gear to simulate other combinations. I have 2.95 first gear and 3.73 (=11) gears in my Monte Carlo and it is wonderful. The 3.50 1st gear and 2.73 rear were a great 1st gear combination (=9.56) in my wagon. I found 3.11 and 2.73 (=8.49) a bit more difficult to deal with in first gear in my wagon.
Malibu Monte
Asking price seems high for what is there.
I was going to offer $50 for the shape it's in, I would have to tear it all apart regardless. I paid $150 for the one in the car now and it worked fine until those teeth chipped somehow...
It was the weirdest thing, I simply forgot it was in gear when I started the car, and I let the clutch out while the engine warmed up a little... stalled, started it back up and then I heard it from the moment I left the parking spot.
4,761
I looked at the pictures again and the tailhousing is from an H body, so it is likely a 4 speed. Check the number of rings on the input shaft to determine if the first gear is 3.50 or 3.11; those were the only 2 ratios that came an H body.
In a Saginaw of that era, the cluster and 4th gear are a set. First, second, and third are the same for all ratios.
$100.00? I remember getting really GOOD Saggy's for that or less in the late 80's...
4,761
I found this detail in a forum:
No grooves 2.84, 2.01, 1.35, 1.00
1 groove 2.54, 1.80, 1.44, 1.00
2 groove 3.11, 2.20, 1.47, 1.00
3 groove 3.50, 2.47, 1.65, 1.00
I was once told that the 2.54 is hard to find. I don't know what it came in.
The 3.11 was used in V6 Monzas
The 3.50 was used in Vegas and 151 Monzas
The 2.84 was used in 2nd gen F bodies
There may be other applications; those are the ones I have come across.
