I know that this issue probably (hopefully) happened to someone else also. I have a serious charging problem. I am running a 140 Powermaster alt and have a red top Optima battery. My problem is this. If i let the car sit for about 4-5 days then the battery goes dead. But, when i am driving it the Autometer gauge runs at 14.2 sometimes then when my electric fan kicks on it drops to around 13 volts. I don't understand the drop off. I have no heater, a/c, or big stereo components. I only run the necessary electrical parts (pump, fan, MSD,). I am also running a M.A.D. wiring harness. I was told by M.A.D that my 3 wire system should handle everything and hold a constant 14.2 charge no matter what i am running due to the 3 wire system sensing the voltage drop and thus adjusting the charging of the alt.
I have already done pulled all my fuses to see if that finds my draw but found nothing that did. Also, when i hit my brakes my voltage drops off for some reason just a little but i have never seen this or heard of this before. Has anyone else? I am at my last wits end and nerve here someone help me out please. ](*,) :cry:
