Flexplate hitting starter gear.
SuperShop
316
everywhere n chicago
383
I am Having The Same Dam Problem, Just Found Out Last Night, Got Under Car Turned Over Crank With Pipe Wrench While under Car Found Out Flex Plate Is Bent!!!!!! It Was Moving In Toward Starter And Out Away From Starter As I Turned It!! Exact Same Problem.With Mini Starter, I Thought It Was Just Me With That Weird Problem.......New Flex Plate Will Be In This Weekend.
cleetus
180
NJ
How you gonna go at it? I JUST put the g-damn motor in, and I don't want to rip it out, nor do I want to have trans fluid all over the place. What a f-ing mess.
I'm going to try to take some of the nose off the starter gear. If all goes well, I may not need to do a flexplate job. If it doesn't, I'll spend the extra $35 for a new gear AND the extra $100 or so for a balanced flexplate.
SuperShop
316
Flexplate
I Just Put Mine In Too, But I Was Always Told If Your Gonna Do It Do It Right! So I'm Going To Pull The Trans Back And Change It, Dont Grind The Nose Of The Starter Down! Trust Me You Will End Up Spending More Money On A New Starter Been There Done That All Last Week. When It All Done And Over You'll Say I'm Glad I Done It Right Instead Of Taking Short Cuts. I Don't Know About You But I Don't Want To Go Through It Again, So Thats Why I Say Go Ahead And Do It Right The First Time That Way You Won't Have To Do It Again :)
cleetus
180
NJ
With a little nip of the nose, the grinding is gone. Still, it's a temporary fix...
If the flexplate is bent, it more than likely is going to kill your pump and front bushing in your trans. It may also cause a vibratiion that will eventually crack the bellhousing on the trans. Yank the trans and replace it. I wouldn't chance it. Your $50 flexplate may cost you a trans and converter.
If the flexplate is bent, it is going to kill your pump and front bushing in your trans. It may have a vibration in it that will eventually crack the bellhousing on the trans if you let it go as well. Don't let a $50 flexplate cost you a trans and converter. Yank it and fix it right.
