Lets see some engine pics
malibujoel
100
Plymouth , MI
wrenchrat kit
yahr
42
Brick New Jersey
nawlins-tim said:
Hey 1quickGM..What make are those headders? Motor is clean for sure!!!!!!!11
They look like the hooker supercomps 1 3/4 the last tube on each side goes outside the framerail. I had them on my old bu but I thought they fit like $hit. They work but with the heads I ran they burned plug wires all the time not to mention the tires if you turned too far. 2242hkr 520.00 uncoated
The heddman husler 65112 header was 1 7/8 and all the tubes fit inside the framerail. Plus plug fitment and starter fitment were great. A little pricey though 770.00 uncoated
1QuickGM
386
Niles, Michigan
Thanks for the compliment Nawlins!
Yahr is correct they are Hooker headers.
Yahr my headers rubbed a bolt on the lower control arm but that was my fault, I had the wrong motor mounts which set the motor higher. But you are correct the tires do rub the headers!
Never really worried about the rubbing tires, just made sure not to make hard turns, which with a spool I didnt do anyways.
yahr
42
Brick New Jersey
Yea I remember that bolt too. I had to turn the lower control arm bolt around so the nut side was the other way.
mybu78
1,276
westminster,md 21157
