You sure that is the right part number? Summit doesn't say anything about them being set back 1".
http://www.summitracing.com/parts/TRD-4592/Application/?prefilter=1
Again looking at Summit, it says 4595 are the 1" setback ones.
http://www.summitracing.com/parts/TRD-4595/
transdapt#4575 are the one inch set back for sb chevy #4592 are the stock location plates for the sb chevy both you can use the clamshell mounts and youre good i got the stock location ones and just found out by mounting them with my th350 trans i need the one inch setback for my trans to bolt in the stock location with the cross member that way my driveshaft is where it should be im looking for pics as we speak will post up if anyone needs them...
