LS engine swap mount question
lt4malibu
2,384
NJ
what part number engine mount adapter plates are you guys running for the 1" set back? edelbrock 6701?? it doesnt specify if its a 1" setback or not.
thanks!
Kevin Williams
139
Autryville,NC
www.angelfire.com
Transdapt 4592 are 1 inch set back.
blubaldmontess
872
Clarksville, TN
Those transdapt ones are the same ones that I ran too, great stuff
samckitt
50
Carrollton, VA
You sure that is the right part number? Summit doesn't say anything about them being set back 1".
http://www.summitracing.com/parts/TRD-4592/Application/?prefilter=1
Again looking at Summit, it says 4595 are the 1" setback ones.
http://www.summitracing.com/parts/TRD-4595/
G-BUDDY
Member
Jan 20, 2011
8
transdapt#4575 are the one inch set back for sb chevy #4592 are the stock location plates for the sb chevy both you can use the clamshell mounts and youre good i got the stock location ones and just found out by mounting them with my th350 trans i need the one inch setback for my trans to bolt in the stock location with the cross member that way my driveshaft is where it should be im looking for pics as we speak will post up if anyone needs them...
blubaldmontess
872
Clarksville, TN
you can also use something like this:
http://www.dirtydingo.com
We just ordered them and we'll be using them on a camino with the stock motor mounts...will let you know results
