My Pro Touring conversion
Meat Drapes
1,198
9
Stoutland, MO
Stabbed the motor in only to come to the conclusion that the 2241s do not clear the new hyd clutch master location. Someone commented this would happen. I dont listen. So now I need new headers. I gave the old setup away. This build is gonna kill me.
shoedoos
156
12
18
Meat Drapes said:
shoedoos said:
Nice project, I looked at buying your car from the original owner about 6-7 years ago. Not to put a damper on your efforts, but I discovered the floor panel in the driver footwell was all bogged up......might be worth a look on your part.....
I bough this car in 2005 from a fellow Marine at the Camp Lejeune commissary lemon lot. I know every nut and bolt on it. There is nothing 'bogged' whatsoever. There is no damper on my efforts other than my 'older' age and 26 years of service that hurts me when I crawl under it.
Looks to be the same car to me.....not bagging your build, just letting you in on something the original builder (Jeff H) and I discussed....
TURNA
6,028
Socialist NY
Plastic oil pressure line?!?!!?!?!?
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!
Meat Drapes
1,198
9
Stoutland, MO
HAHA!! I ran my HV oil pump on plastic in that car for over a decade. Never leaked a drop.
TURNA
6,028
Socialist NY
I would just be worried about it melting and then getting stuck
Meat Drapes
1,198
9
Stoutland, MO
My second attempt at installing the trans. First go was brutal. Im losing my edge.
Meat Drapes
1,198
9
Stoutland, MO
Bled the clutch today using a Harbor Freight vacuum bleeder. Worked really good.
malibu795
1,497
spgfd ohio
Meat Drapes said:
More pics of goodies going into this build.
Didn't catch it Ori missed it... Who's spindle/rotor/caliper did you use?
Meat Drapes
1,198
9
Stoutland, MO
TURNA said:
That is the Blazer 2wd upgrade
Yes. I got the spindals from a junk yard. Got new bearings, calipers and rotors from Rock Auto.
