Here is what i was quoted from QP. Does this seem like a decent deal guys?
They claim , that the new housings have new ends and eliminate the leak that has occured with the old housings used as cores.
$845 - 9" Ford Housing/Axle Package (79 Malibu)
- New Housing Center w/ New 3" DOM Tubing
- New Billet Steel Big Ford (Old-Style) Housing Ends
- New Axles, Axle Bearings, Wheel Studs, & Retainers
- 31 Spline, 5 on 4-3/4" Bolt Pattern, 1/2" Wheel Studs
$55- Drain & Fill Plug w/ Jack-Pad - Installed in Housing
$1120 - 9" Ford Center Section (Assembled) ** ALL NEW PARTS **
- Yukon Nodular Iron Pro N-Case w/ 5/8" Cap Bolts
- Aluminum Daytona Pinion Support
- 1350 Billet Steel Yoke
- 31 Spline Ford Motorsports Trac-Lock Posi Unit
- Motive Performance Gears (3.70 Ratio)
- Timken USA Bearings
$369 - 11" Disc Brake Kit w/ Parking Brake
Thanks
Thanks
