92Camaro said:When you load up on the converter you used up the lobe on the cam for the pump shot. Try moving the cam to position 2 and loosen up the pump arm a little. Also buy the pump cam assortment kit. Its just like buying a cam. It will offer different opening rates to adjust the shot.
92Camaro said:When you load up on the converter you used up the lobe on the cam for the pump shot. Try moving the cam to position 2 and loosen up the pump arm a little. Also buy the pump cam assortment kit. Its just like buying a cam. It will offer different opening rates to adjust the shot.[/quote
wow, why didnt i think of that! let us know if this works out.
