I guess I do have a series of questions. Thanks bottle baby bu in advance for any advice you can throw my way.
I am putting together a 406, with a 3 fold duty.
1. Bracket racing no nitrous
2. Occasional test and tune night sprays.
3. very very limited street duty, like to the burger joint and back a couple times a year.
I have alot to say so I will try to be succinct and understandable.
These are the parts I HAVE.
Little M block
Callies stealth 3.75 stroke crank
Manley H beam 6 inch rods
Pro Topline 235cc heads
Comp Cams .699/.704 .271/
[email protected]" 113 ls 4/7 swap solid roller
super victor intake
TMP 1000cfm carb
JW Ultra comp converter
NOS pro Shot Fogger with its own fuel system.
I need to buy pistons, and have been plannin on about 13 to 1 static range. They will be top notch pistons but I still have not totally chosen a brand yet. Diamond, CP, JE, and BRC are all in the running.
So on to the questions, sorry if they are inspecific.
1. What do you feel is the maximum SAFE level of N2O it will take with a good tune?(Conservatively) I am not interested in going to the ragged edge of my parts, and the rods are good, but pretty lightweight.
2. What Compression ratio would you aim for? NOTE: I'd like to run 110 cam2 for non nitrous duty.
3. I have a separate fuel tank for my nitrous kit, if I were to run c12 or c16 in there, would the cam 2 in the regular tank lead to detonation when spraying?
4. The converter is made to hold up, but set up to run without N2O, I do hav a multi step retard, Are there any other things I should consider for limited nitrous use, considering it will likely be a decent size shot ~250 to 300?
5. What rings would you recomend?
6. How about head gaskets. I have a set of Fel pro 1034's. SHould I buy different ones? And when does Oringing the block become critical?
Thanks a bazillion.
