NOS button on steering wheel
Brian79
383
Wataga, IL
Is there a steering wheel made that has a button on it to push when you want to hit the NOS shot? Thought I've seen one before but can't find it now.
turbu
54
south side chicago
you can use the horn button on a stock steering wheel if you needed.
SS402
84
Lakeland, Florida
I Do Not advise mounting the NOS activation switch on the steering wheel, if you just happen to be cruisin around with the NOS armed n dangerous and are involved in an accident or have to make an emergency stop or some other unplanned event the LAST thing you want is the Nitrous to accidentally come online..
mount the system Arm switch in the dash and use a microswitch on the carb for activation
eldabo
1,811
Mobile,Alabama
In a panic stituation the first thing that comes up is your foot not you hand (dont ask how I know) and that = bad things happen and makes weird sounds after that,and has blow by pumping out of the valve covers.
Hiway
3,932
Enola Arkansas
I've ran the button on the wheel thru the horn circuit several times. I alway ran the micro switch at carb along with arming toggle. You can put your foot in it and thumb control your spray as needed this way...for the conditions. In a panic...your foot is off the gas so there is no spray issue.
