Will a 91 Camaro posi unit fit in a 83 El Camino 7.5 rearend?
attngtr Frequent Racer Sep 20, 2007 364 0 0 Eastern Iowa Feb 4, 2010 #1 Will a 91 Camaro posi unit fit in a 83 El Camino 7.5 rearend?
B bowtie81 Moderator Mar 28, 2008 5,008 0 36 sarnia, ontario canada Feb 4, 2010 #2 Im pretty sure as long as the spline count is the same as the axles you should be alright.
attngtr Frequent Racer Thread starter Sep 20, 2007 364 0 0 Eastern Iowa Feb 4, 2010 #3 What is the spline count on a 7.5 G-Body rear? Is it 26 splines?
B bowtie81 Moderator Mar 28, 2008 5,008 0 36 sarnia, ontario canada Feb 4, 2010 #4 attngtr said: What is the spline count on a 7.5 G-Body rear? Is it 26 splines? Click to expand... yes sir it is.
DOUG213XRJ MalibuRacing Junkie Sep 18, 2006 4,671 1 38 West, MI Feb 4, 2010 #5 the 78-87 7.5 rears have 26 spline axles, 1988 and up are 28 spline, So the axles have to be changed to 28 spline.
cutlass389 Frequent Racer Feb 2, 2009 684 0 0 NC Feb 4, 2010 #7 I ran a posi out of an f-body with 28 spline Moser axles for a few years. It did fine until I started to get a little air under the left front. [-X
