Like monzaz said, But be aware of 1 thing, The 78-87 G-bodies had both 7.5" {7&1/2}rearends and 7&5/8" rearends with 26 spline axles. The 7&5/8" rears were common in the Monte SS's The only difference is the inner pinion bearing {closest to the teeth} and its race. The 7.5 has a visibly slightly smaller diameter. All other bearings are the same. On the outside the housing looks exactly the same. All the other parts, axles, carriers, backing plates, etc are interchangeable. The Carriers will exchange with all S10's, F-Bodies, and G-Bodies with the correct spline count. I guess GM's thoughts were putting that Whopper of a 305 in the SS's :lol: :lol: would put a strain on the pinion bearing!
Just something to keep in the back of your mind if you are going to replace the Ring and Pinion and/or bearings.
Good Luck!
