rear disc using weld-on/bolt-on caliper brackets ?'s
rjleiker
261
Derby, KS
Those spherical rod ends/stabilizer bars on your housing... Are those worth it? do you think they would make very much difference?
I want my 7.5" to last as long as I can get it to. I am already going to put one of the differential support housings like that on mine, but that looks like a good idea to try to add some more life to it...
Did you put those on or did a builder do it or manufacturer?
355_79bu
1,240
Cotter, AR
It was a kit from Ultimate Performance Products called a tube brace kit. I had all the hardware and and the two chromemoly tubes. I had to cut them to length and tig the threaded bungs on the ends for the heims. Also, of course , I had to locate and weld the mounting brackets on the housing. Does it help? I can't really say for sure. It cant hurt. The cover I bought had the provisions for it, so while I was there I went ahead with it.
BTW: As far as the rotor diameter, the ones from speedway were 11".
