Elky said:Ya I was meaning on a 'single' stage system if you have 1 button, and you push it, say shift gears and push it again.
Or can you put your trans in drive and push the button the whole run? or wait till you hit second gear?
Sorry about this, like I said though... I'm new to this nitrous stuff.
With a single stage you just use it at launch or right after...usually above 2500rpm. if you run a automatic you can hold it down the whole time, after you takeoff. and you can manually shift the automatic trans while using the nitrous. the only time i would suggest to let off to shift, is if you are running a manual transmission.
