Wicked 6 said:Installed new upper control arm bushings. Still have a noise that sounds like metal hitting metal when I go into a turn.
HP JUNKEY said:Pulled rear-end apart to swap out carrier, will put back together Sat. night, spotted a Griffin G-body Radiator on local Craigs list and scored it for $80! gonna go in my sons Cutlass when ever he decides to get wrenchin' on it. Oh ya, and I got a f'n ticket on the way home,,,,,,,,,,,,,,,,72 in a 55,,, #-o,,, not such a good deal on the radiator after all curse_sign.gif curse_sign.gif
I'll give you a call and we'll set something up. A guy told me it might be one of the front springs is out of place. Not sure how that could happen but I did roll the car around without the motor quite a few times so not sure if that would do it.MUSCLEALMIGHTY said:Wicked 6 said:Installed new upper control arm bushings. Still have a noise that sounds like metal hitting metal when I go into a turn.
Maybe, I can come by..or vice versa and check it out! You turn the wheel and I will feel underneath and locate it!
Bar50 said:Sounds like ball joints...popping/hitting when you turn...
Well, got the 454 truck motor all wired and plumbed....
Started it up today, without the aforementioned exhaust I scored on craigslist. No happy ending. Motor has a knock, sounds like a rod bearing. Bummer! Go figure, the one time I don't check bearings!!?! I even slapped on a new oil pump and pick up for the car oil pan!?! ](*,)
So, minor set back, gotta stack a motor I have. Needs to be hot tanked with new cam bearings and freeze plugs. Everything else is ready. Another jet boat motor!
It will give me a chance to clean up the wiring and dress up/clean up the engine compartment.
Sucks though, calling the guy I bought it from that said it was a good motor.
Jayz81ss said:Replaced the old body mounts with TNT Aluminum ones. Only had 1 broken bolt (lucky me).
Just picked up a Kirkey Pro race seat and cover brand new for $100. Hope to get it in this weekend.
