bigbadbu
1,579
East Hartford
www.facebook.com
walked around it while i was doing side work need to figure out why the solid motor mounts arent lining up..
Bar50
1,871
Tulsa, OK
Swap them left to right yet?
Swear, they make taller ones...
Is it one lines up, then the other does not?
Anyway, I swapped a 3.42 gear and open carrier into my beater '83 Regal (with Buick 350/TH350) in place of the stock 2.41's. I had picked up a posi carrier with a 3.23 ring gear on it, but the carrier was shorter, and, I didn't have a ring gear spacer...
Now, to tune the Edelbrock carb...freaking surging and dead spot. New lines, new filter, new stock mechanical fuel pump. Tried all the combinations of jets and rods for the electric choke carbs...ordering the manual choke kit....probably gonna' have to set the lash/pre-load on the push rods a little tighter, getting a lifter tick on start up after she sits a while.
Gotta' play Regal, to play G-body, until the 454 for the cheap Malibu project is done at the machine shop!!?!
PS
What coil springs should I put in it? Its sagging pretty bad...442 or Monte SS or GN or ??? The 350 Buick V8 is not much (40 or 60 pounds heavier than the 3.8 V6).
LIVE4RDO
678
Staten Island, NY
Getting my interior ready for Lizard Skin treatment and some POR 15 on the roof
melloelky said:
MUSCLEALMIGHTY said:
LS6 Tommy said:
Put my stay-down license plate holder on.
WHERE DID YOU GET THAT PART?
i think those b-body caprices have them?
E-bay... GM part #14083879. I think Kirban sells them, too.
Blue Knight
383
Swapped an open 2.41 rear end with a 3.08 posi.
Also registered and tagged the car.
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
dropped it off to get the headliner re-done, getting it back tomorrow
Blue Knight
383
Where the ashtray used to be (now a three gauge pod) there was alight that was ungodly bright at night.....well $15 at autozone I had some blue leds wired in....
And then went to the bar after that washed theb bu
Wicked 6
978
Ansonia, CT
changed the rear shocks on the elky and adjusted the carb on the malibu...still not running right might need to rebuild it.
