1980PontiacWagon
686
Northern Virginia
Doober said:
Piston said:
What radiator did you go with? I'm about to do the same with mine... copper has got to go. I'll also get rid of the belt driven fan while there.
A clutch fan won't necessarily rob any power, a solid-mount one will though, plus I've heard of horror stories... people being hurt, radiators punctured, hoods damaged, etc. from those flex fans coming apart.
My car actually stays cooler with a clutch fan..I've heard some places that the flex fans at speed the fins flatten out and actually just block air, while the clutch fan has heavy duty blades and usually isn't spinning at highway speeds.
Yeah, but you definitely know if the fan clutch seizes! I had one do that on my '88 full size pickup, there was a noticeable decrease in power.
HOLY TERROR-BU
2,503
WATERBURY, CT
IVE ALREADY TALKED ABOUT MY PROGRESS WITH THE BU. HERE ARE SOME PICS OF WHAT I BEEN DOING.......
HERES SOME PICS OF THE OL' RATTY DASH:
....IN GOES THE NEW DASH! STARTED OUT AS MAROON...CLEANED, PREPPED..THEN SPRAYED USING SEM BLACK.
ALSO REPLACED THE FRAME ON DRIVERS SIDE! AS U CAN SEE, THIS THING IS ON IT'S LAST RITES!!
PLANNING STAGE: DECIDED TO CUT AND WELD THE FRAME PIECES LIKE A PUZZLE. DOING SO, ADDS STRENGTH TO THE FRAME...RATHER THAN A STRAIGHT CUT!
BODY MOUNT HOLE: MY REPLACEMENT FRAME PIECE, DIDN'T HAVE A PERFECT ROUND HOLE FOR THE MOUNT. SINCE IT WAS EGG SHAPED, JUST PLACED A 2 1/2 WASHER OVER THE HOLE. I DIDN'T MEASURE...JUST EYEBALLED WHERE IT LOOKED RIGHT.
*I USED A THICKER THAN USUAL WASHER. I TRIED RUNNING A HOLESAW THRU IT..NO LUCK...IT WAS WAY TOO THICK. TOOK A DRILLBIT AND PUNCTURED HOLES TO WHERE THE MOUNT WOULD FIT. ONCE DONE, WENT AT IT WITH THE SAW...AND SUCCESS!!!*
JUST ABOUT TO BE FITTED AND WELDED IN PLACE. OPENED UP THE SIDES A LITTLE TO ALLOW BETTER FITTING. ONCE FITTED, PRESS PIECES TOGETHER FOR GLOVE FIT!
JOB WELL DONE! PLACED THE BODY MOUNTS AND DROPPED HER DOWN. EVERYTHING LINED UP BEAUTIFULLY...ON POINT!!!!
***SPECIAL NOTE***
EVEN THO HE WILL NEVER SEE THIS POSTING, JUST WANTED TO GIVE SPECIAL THANKS TO MY INSTRUCTOR (LOUIE CUPERO), FOR GUIDING ME THRU THIS! DOING THIS PROJECT HAS GIVEN ME EMMENSE AMOUNT OF KNOWLEDGE. GIVING ME DIFFERENT PERSPECTIVES ABOUT HOW TO TACKLE SOMETHING! YOUR GUIDANCE DIDN'T GO TO WASTE. BELIEVE THAT!!!
malibu795
1,497
spgfd ohio
tore the rear end out got drive shaft redone. difference between a 7.5 and a 8.8 hybrid is 3/8" longer for the 8.8
81rustabu
859
pinckney,MI
Drove the rustabu to work and did fat burnout. Let her scream some rpms....
