malibu795
1,497
spgfd ohio
told the machine shopt to get working on my new 468BBC bore, main bore, decked, balance and get assembly ready..
looking at going HR setup this time..
HarrisonTX
3,332
Burleson TX
Put a freaking TKO500 in. HELLO OVERDRIVE
Wicked 6
978
Ansonia, CT
Took out the driver's bucket seat. They did a horrible install on it and it looks like there was different seats in there before because I found extra holes on the floor. Both seats have a bad lean. they're are the same color but different styles so thinking of going with a bench seat for now. Will post pics to see if anybody can identify what car they came from.
They probably lean because I'm guessing they used the outside mounts? The seats in my '81 are like that, it was before I became familiar with the way G-Body seats are mounted. My '78 had a split bench so it had all the mounts for buckets... found a set at a local junkyard for $40 and they bolted right in :D
Wicked 6
978
Ansonia, CT
There are no inside mounts as this was a bench seat car they just bolted these up to the outside mounts. I've made mounts for buckets before but might just put a bench seat back in or get a set on mounts and weld them in. Both seats are passenger side seats and different styles so unless I find a matching one will probably get some monte seats.
454RAT
2,012
Summerville, SC
Grooved the distributor .030 for better oiling on my cam/distributor gear and cleaned up my MSD distributor and put it all bacl together. Installed my intake that I gave a home made clean up on the plenum and runners as they transition into the heads. All I have left is to adjust the valves and fire it up. Then I get to pull the transmission and send the converter off to be tightened up so I can try to hit the track before the end of the year.
HOLY TERROR-BU
2,503
WATERBURY, CT
HELPED MY WIFE, TAKE APART HER MALIBU! SO PROUD OF ALL THE HARD WORK SHE'S DONE!!
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
took mine for the last long drive of the season. took it up to the white mountains for the day. it was a nice trip and took lots of good pictures.... then accidentally dropped my camera in the river ](*,) i retrieved the camera, but all was lost (so far). drove all the way up to Crawford Notch, and this is what i snapped... hopefully the last time the malibu and snow get to meet!
Dood! That sux! I'm not bustin', but that 's why I never use my cameras without the wrist or neck strap on...
MISFITmalibu63
7,163
i had it in the pocket on my flannel shirt, and i jumped from one rock in the river to another and it launched out of my pocket. i juggled it 4 times before it went out of reach and went for a swim. my girlfriend was laughing uncontrollably at me because she said, "Hollywood couldn't have done it better" i was able to save the SD card though, so i do have the pictures.
