Embryo
25
54165-WI
Pulled my headliner and recovered it since the previous owner decided to spray paint it and then pulled my dash in preparation for installing the new cover.
bigbadbu
1,579
East Hartford
www.facebook.com
got it all buttoned up..hit the go button and no spark...oh yeah and my brand new(been sitting on the car a year) water pump is cracked...so new water pump and have to find the spark gremlin..what plug wires are you guys using? I cant seem to find a build your own kit with 135 degree boots
lasttime78
465
Took and rebuilt my speedometer and got a new odometer to put in. I could have gotten new instrumant panel altogether but mine is emaculate. I even found an original clock in the El Camino that I got the speedo out of, took a chance on it working and it does it was free. Spent 30 dollars for new speedo and odometer.
The Junk yard I went to today had three differant Monte instramant panels everything there and two Pontiac Dashes with alot of gauges. The yard has some good g-body stuff.
Embryo
25
54165-WI
Tonight I finished pulling the factory climate control system in preparation for mounting the new Vintage Air heat/defrost unit. All the clamps got removed from the dash cover after 24 hours of cure time and I then sprayed the jams with SEM Landau Black since they were baby blue at one point in time.
Wicked 6
978
Ansonia, CT
Took out the nasty carpet that was in the malibu and this is what I found
hack job
driver's side not to bad
pass side not so good
melloelky
3,654
mass
well,if you think about it,its not THAT bad being from new england rite?
lasttime78
465
hack job
They all do that above the cadilc converter area, because of the heating up and cooling down . Not to mention the condisation that happens from that . Was that hole covered just by carpet?
lasttime78
465
Stopped on roll bar install and decided not to install it . Did not want to weld or bolt to floor . Car is in too good of shape to do that .
Blue Knight
383
Started making my move..
Wicked 6
978
Ansonia, CT
It came from PA then upstate NY and now CT so not bad beside the hack job for the shifter. I got a section of floor from another gbody with the inner bucket seat and console brackets so will be doing some cutting and welding.
