Okay. I understand what relays are used for now I have a few questions.
Pertaining to electric fans. Is it possible to purchase the correct relay and toggle switch and turn on dual fans at the temp desired instead of a temp sending wiring kit? If so, How?
I currently have an ignition kill-switch in my 81 bu now. I also bought a Keep It Clean (4-wire) push button starter that is awaiting install. Is it possible to wire in the push button and have the ignition kill switch wired at the same time? if so how is it done? Thanks
