2 or 3 series Auburn limited slip carrier?
Damon
1,655
Philly Area
Pfffffff..... probably. Couldn't tell you the measurement or where to measure it from, though.
I'd contact Auburn and ask them. It's only a difference in the location of the ring gear mounting flange.
1981Regal
1,274
Cincinnati, Ohio
I was told it was removed from an 1986 olds with g80 rpo code. I count 26 teeth on the side gears. It does have some stamped numbers on the carrier. No ring gear or pinion. It's probably a 7.5 ring gear and I'd have to lean towards it being a 2 series.
HP JUNKEY
1,093
Buffalo.NY
Here is a measurement of my 2 series Auburn 7.5" carrier, should be the same measurement for the 8.5".....
I run a "thick" ring gear...........Series 3 will take a "thin" or "regular" ring gear...........
