I have a 1980 El Camino with a 4.4 Liter 267 V8 and TH350 transmission. I rebuilt the original 2 barrel carb and put it on, hooked all the original vacuum lines up since they were rotted and blocked off by the PO. I just got the car not too long ago and only drove it straight to my house and then started tearing it apart because of a major ant problem I had. Other than that I just start it to move it around the driveway and garage, that's it. Even then I have probably only started it a total of 20 times ever. It used to always smoke on startup because of bad valve seals I guess but would stop after a minute or so. Now it's been sitting a week or more and I just put the carb back on, started it and it smokes (white smoke) like crazy and wont stop. I only let it run for a few minutes because it filled the garage with smoke and then it filled the room just inside the garage with smoke.
Not sure what to do here or what it could be? Also seems to be running VERY rich and smell of gas and oil out the tail pipe even with the carb rebuilt, cleaned and gone through.
Any info would be greatly appreciated!
