I just drilled new holes in the frame. I had a hard time getting the motor to sit in there using the stock bolt hole locations. I ended up just bolting the mounts to the motor, getting it where I wanted and then scribed the spots for the holes on the frame.Doober said:![]()
I came back to read throughI actually have a question too
You first said you moved the motor back 1¼", but then went to about ¾". It says in this pic the mounts moved it back the 1¼", what did you do to gain ½" back?
